How to set default units when importing autocad data on Inventor
toznal
toznal
Hi, there.
I have a question about setting default units when importing AutoCAD data.
I usually use millimeter on Inventor and AutoCAD.
When I import AutoCAD data into Inventor sketch, I have to click right mouse to check importing units.
It's kind of bothering to change units every time.
So, Is there option to set default units for importing cad data?
Please help me.
Thank you!
johnsonshiue
Hi! If you go through Open -> Import. The dialog options follow last used options or you can load an xml file with preset options. You can specify unit or you let Inventor detect the unit.
If you import the file as a sketch in a part, the unit would be dictated by the ipt document setting (Tools -> Document Settings -> Unit). Inventor is a true-scale modeler, the geometry does not scale based on the selected unit. Only the measurement is adjusted according the unit setting. If it is still a bit confusing to you, feel free to post an example here or send it to me directly (johnson.shiue@autodesk.com).
Many thanks!
Software Test Engineer
toznal
Hi!
Thank you for response.
I'm sorry I made you confused.
I meant set to default units about when using control + C , control + V.
http://help.autodesk.com/view/INVNTOR/2017/ENU/?guid=GUID-541DB455-8FC7-4CEC-BC4C-E270864217E4
I was just wondering if you could check this please?
Thank you!
JDMather
Let's start at the source, type -dwgunits in AutoCAD. What does the command line say?
