how to separate solid into other solids
trebulas
trebulas
they sent me this file with the modeling of a closet. The problem is that only the closet doors are separated in solids. Everything else is as "solid body 1". I wanted to know how I can separate the closet parts to make the exploded view.
James_Willo
Split tool would work as Gabriel mentioned, but you'll end up splitting parts you want to be a whole part.
You'll need to use 'combine' to rejoin these unwanted splits after.
Once you're done, use the 'make components' command on the manage ribbon to split them into separate files.
James W
Inventor UX Designer
trebulas
huuum, its my first time using Inventor but its a pretty simple solution, thanks!
trebulas
Got it, I'll remember your suggestions, thank you very much
