How to select several browser nodes using Inventor API
Anton_Chernomazov
Anton_Chernomazov
I'm using Inventor API to execute some command definition for single browser node. I need to execute this command for several browser nodes. But when call DoSelest method for next one previous Selected value becames false. How I can select several browser nodes using Inventor API?
Anton_Chernomazov
Yes, I have seen this post. But I'm sure there is must be simpler solution. Using CTRL key is not gracefully in my opinion))
JhoelForshav
Ok,
After doing some research I'm pretty sure that there is no way to do this with API-functions alone.
I'd say there is no "graceful" solution to this problem. @HideoYamada 's solution works and in my opinion it's a great "workaround". After all the end user will not see the code. Only the result of it 🙂
Anton_Chernomazov
All right, you have persuaded me 🙂
