How to select multiple browser nodes
Message 1 of 16
I have object collection with browser nodes. I tried to add this collection to oDrawDoc.SelectSet.Multiple(oObjColl) but it failed. I know that brower node has method "DoSelect" but it works per browser node and not for multiple nodes at once. How should I "DoSelect" multiple nodes?
Replies (15)
Message 2 of 16
HideoYamada
Hello danilo.veljkovic,
Try make a ObjectCollection of the BrowserNode.NativeObject and SelectMultiple  it.
Here is a sample code.
Sub test()
    Dim nodes As BrowserNodesEnumerator
    Dim node As BrowserNode
    Dim oc As ObjectCollection
    Set oc = ThisApplication.TransientObjects.CreateObjectCollection
    Set nodes = ThisApplication.ActiveDocument.BrowserPanes("PmDefault").TopNode.BrowserNodes
    For Each node In nodes
        Debug.Print TypeName(node.NativeObject)
        If TypeName(node.NativeObject) = "ExtrudeFeature" Then
            oc.Add node.NativeObject
    Next
    ThisApplication.ActiveDocument.SelectSet.SelectMultiple oc
End Sub
Good luck!
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 3 of 16
Thank you for the reply.
I have oCompOcc from oObjOccColl object collection and I get Native object for each occurrence. oAsmBN is node I want to select sub-nodes within.
This is what I am doing with the code:
    Dim oNativeBrowserNodeDef As NativeBrowserNodeDefinition
    Dim oTargetNode As BrowserNode
    Dim oCompOcc As ComponentOccurrence
    Dim oObjColl As ObjectCollection
    Set oObjColl = ThisApplication.TransientObjects.CreateObjectCollection
    For Each oCompOccEnum In oObjOccColl
        For Each oCompOcc In oCompOccEnum
            Set oNativeBrowserNodeDef = oAsmDoc.BrowserPanes.GetNativeBrowserNodeDefinition(oCompOcc)
            Set oTargetNode = oAsmBN.AllReferencedNodes(oNativeBrowserNodeDef).Item(1)
            Call oObjColl.Add(oTargetNode)
            Debug.Print oTargetNode.NativeObject.Name
        Next
    Next
    Call oDrawDoc.SelectSet.SelectMultiple(oObjColl)
Last line ends in "Method 'SelectMultiple' of object 'SelectSet failed" error message.
Message 4 of 16
HideoYamada
Can each item of oObjColl be added individually to SelectSet?
I don't understand exactly what you want to do, but
you shuld
Call oObjColl.Add(oTargetNode.NativeObject)
instead of
, I think.
Best regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 5 of 16
Hideo,
NativeObject, in my case, is Occurrence. But want to select browser node for given occurrence. Browser node has DoSelect method but I cannot use it because I want to select multiple browser nodes. Just like we use Ctrl+Click to select multiple browser nodes, like this:
My code is for drawing module of inventor.
Message 6 of 16
HideoYamada
Oh, drawing document...
As far as I know, there is no way to select the browse nodes in drawing document via SelectSet.
Because the object type of there nodes does not disclosed.
Sorry for not helping.
By the way, What will you do after selecting multiple browser nodes?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 7 of 16
I checked the same way how SelectSet gets BrowserNodes. 🙂
Message 8 of 16
Selecting browser node will highlight components in drawing view based on certain search criteria.
Message 9 of 16
HideoYamada
How about a way to select all of drawing curves corresponding to the component instead of selecting browser nodes?
(It must be slow...)
Freeradical
 Hideo Yamada
Message 10 of 16
I already made this code but, as you've said, it is slow ... so i thought to make it faster ...
Message 11 of 16
HideoYamada
I have posted about this issue on Idea Board.
https://forums.autodesk.com/t5/inventor-ideas/please-disclose-the-type-of-browsernode-nativeobject-i...
Please vote and comment more information!
Best Regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 12 of 16
HideoYamada
Finally I got it!
Select Multiple NodesSelect Multiple Nodes
Option Explicit
Private Declare PtrSafe Function GetKeyboardState Lib "user32" (pbKeyState As Byte) As Long
Private Declare PtrSafe Function SetKeyboardState Lib "user32" (pbKeyState As Byte) As Long
Private Const VK_CONTROL = &H11
Private keys(256) As Byte
Private save As Byte
Private Sub SetCtrlKey()
    GetKeyboardState keys(0)
    save = keys(VK_CONTROL)
    keys(VK_CONTROL) = &H80
    SetKeyboardState keys(0)
End Sub
Private Sub ResetCtrlKey()
    keys(VK_CONTROL) = save
End Sub
Private Sub SelectPartsLoop(nodes As BrowserNodesEnumerator)
    Dim occ As ComponentOccurrence
        Set occ = Nothing
        On Error Resume Next
        Set occ = node.NativeObject
        On Error GoTo 0
        If Not occ Is Nothing Then
            If Left(occ.Name, 3) = "JIS" Then
                node.DoSelect
        SelectPartsLoop node.BrowserNodes
    Next
End Sub
Sub SelectParts()
    Dim obj As Object
    Dim dDoc As DrawingDocument
    Set dDoc = ThisApplication.ActiveDocument
    Set nodes = dDoc.BrowserPanes.Item("DlHierarchy").TopNode.BrowserNodes
    SetCtrlKey
    SelectPartsLoop nodes
    ResetCtrlKey
End Sub
I found that BrowserNode.DoSelect kept already selected items when I held down the control key (yes, on physical keyboard).
So if the keyboard state is changed as a control key being pressed by Win32 API, DoSelect keeps last selecting.
The above code will select all occurrences whose name starts with "JIS" as shown in the screen capture.
How is this?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 13 of 16
Thank you Hideo for not giving up! I totally missed Ctrl button. Smart!
Message 14 of 16
liminma8458
Hi, Yamada,
When I convert your code into VB.NET,  it does not work. It can't select multiple browser nodes any more, only the last one is selected. Do you know why?
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
Message 15 of 16
HideoYamada
The following iLogic rule works fine for me.
Imports System.Runtime.InteropServices
Public Sub Main
	MultipleSelectSample.ThisApplication = ThisApplication
	MultipleSelectSample.SelectParts()
End Sub
Public Class MultipleSelectSample
    Public Shared ThisApplication As Application
    <DllImport("user32.dll", SetLastError:=True)>
    Private Shared Function GetKeyboardState(pbKeyState() As Byte) As <MarshalAs(UnmanagedType.Bool)> Boolean
    End Function
    Private Shared Function SetKeyboardState(pbKeyState() As Byte) As <MarshalAs(UnmanagedType.Bool)> Boolean
    End Function
    Private Shared keys(256) As Byte
    Private Shared save As Byte
    Private Shared Sub SetCtrlKey()
        GetKeyboardState(keys)
        SetKeyboardState(keys)
    End Sub
    Private Shared Sub ResetCtrlKey()
    End Sub
    Private Shared Sub SelectPartsLoop(nodes As BrowserNodesEnumerator)
            occ = Nothing
            On Error GoTo 0
                    node.DoSelect()
            SelectPartsLoop(node.BrowserNodes)
        Next
    End Sub
    Public Shared Sub SelectParts()
        Dim obj As Object
        SetCtrlKey()
        SelectPartsLoop(nodes)
        ResetCtrlKey()
    End Sub
End Class
And my add-in that are written in C# works fine.
I have not tried it, but if it does not work for add-ins written in VB.net, then the problem must depend on the VB.net runtime.
Freeradical
 Hideo Yamada
Message 16 of 16
liminma8458
Hi, Yamada,
With your help, I got the VB.NET code work. Thank you so much!
The following code should help if anyone need it!  Call SelectParts() to use it (You need to "Expand All Children" for the drawing browser as in expand_pane_drawing() to make the multiple selection work).
Imports Inventor
Public Class cls_browser_node_drawing
    Dim ThisApplication As Inventor.Application
    Private Declare Function SetKeyboardState Lib "user32" (pbKeyState() As Byte) As Boolean
    Private Declare Function GetKeyboardState Lib "user32" (pbKeyState() As Byte) As Boolean
    Private osave As Byte
    Dim oDoc As DrawingDocument
    Public Sub New(AppObj As Inventor.Application)
        Try
            ThisApplication = AppObj
            oDoc = ThisApplication.ActiveDocument
        Catch ex As Exception
            MsgBox("There is problem in new(...) " & vbCrLf & vbCrLf & ex.Message & vbCrLf & vbCrLf & ex.ToString)
            Exit Sub
        End Try
    End Sub
        osave = keys(VK_CONTROL)
    End Sub
        keys(VK_CONTROL) = osave
    End Sub
            occ = Nothing
            On Error GoTo 0
                If occ.Name Like "*Ass1:1*" Then
                    node.DoSelect()
                End If
            End If
        Next
     End Sub
    Public Sub SelectParts()
        Try
            Dim oObj As Object
            oObj = oDoc.SelectSet.Item(1)
            Call expand_pane_drawing()
            nodes = oDoc.BrowserPanes.Item("DlHierarchy").TopNode.BrowserNodes
            AppActivate(ThisApplication.Caption)
            SetCtrlKey()
            ResetCtrlKey()
            MsgBox("There is error in SelectParts" & vbCrLf & vbCrLf & vbCrLf & ex.ToString)
        End Try
    End Sub
    Public Sub expand_pane_drawing()
        Dim oModelBP As BrowserPane
        oModelBP = oDoc.BrowserPanes.Item("DlHierarchy")
        Call drawing_pane_expand(oModelBP.TopNode)
    End Sub
    'iterate to expand browser pane
    Private Sub drawing_pane_expand(oTopBrowserNode As BrowserNode)
        For Each oNode In oTopBrowserNode.BrowserNodes
            oNode.Expanded = True
            On Error GoTo 0
            If oNode.BrowserNodes.Count > 0 Then
                On Error GoTo 0
                Call drawing_pane_expand(oNode)
            End If
        Next
    End Sub
End Class
Limin
