How to scale up OBJ file to correct scale
Mustang69
Mustang69
I have OBJ files of humans but when open them they are only about 70mm height
See attached example
Possible to scale up to correct 1:1?
kacper.suchomski
Hi
I don't think this is possible in Inventor.
Kacper Suchomski
harvey3ELEA
For what it's worth, I'm seeing this from that download:
johnsonshiue
Hi! Mesh file is generally unitless. You can "scale" it by importing to different template. In this case, the logical template is inch. You will want to start an inch-based template or select "inch" as the import unit on Import Options dialog.
Many thanks!
Software Test Engineer
SharkDesign
When importing, click the obj file, then click options. You'll be able to pick specific units.
  Inventor Certified Professional
Mustang69
Thanks!   I miss an inch template ...We only work metric.   Do you have one I can test with?
Mustang69
It worked thanks!
