Inventor Forum
How to Save Document Setting Globally?
3 REPLIES 3
ethan_howardMMXXIV
290 Views, 3 Replies
In Drawing mode, I was having a difficult time seeing a view that was selected as the outside dashed boundary was light green. I found where to change that setting in TOOLS/DOCUMENT SETTING/SHEET and change from light green to dark blue. Much easier to see now. Can that setting be changed globally?
Here is the setting I change for reference:
Thank you,
-Ethan
Autodesk Inventor Professional 2022
64-Bit Edition
Build: 287, Release: 2022.2.2 - Date: Fri 02/11/2022
Tags (2)
Labels (2)
3 REPLIES 3
mcgyvr
in reply to: ethan_howardMMXXIV
Nope..
You can set it in your template for all new files though..
@ethan_howardMMXXIV
Ethan,  that setting doesn't appear to be one that can also be set in Application Options.  However, it might be something that you can set in your drawing template, and have it go out to all new drawings.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
I added this enhancement to the IDEAs Forum:
Save Document Settings Globally - Autodesk Community
Technology Administrators
