How to reuse sketches for multiple features
Looking for some advise here from someone...
I have a folded sheetmetal facade panel which requires a random perforation pattern on the face. The pattern of the holes is completely random but there are 3 holes diameter occurring (25mm, 38mm & 75mm). What i have done is created a sketch on the face with a grid of construction lines at 50mm centres and was attempting to plot points for my hole perforations but it's started getting messy with so many points and the 3 different hole sizes required.
Is there any way i can:
1. create a sketch consisting of the grid of construction lines (as per attached part file)
2. create a second new sketch plotting points on the grid (of my previous sketch) for my first perforation hole size
3. create a hole feature for my first hole size (say 25mm)
4. repeat points 2 & 3 for hole sizes 38mm and again for 75mm
or... is there an even easier or better way to achieve what i am trying to achieve??!
Trust this makes sense... Be very glad of any suggestions, thanks!!
Bradley.
TheCADWhisperer
Something like this (see attached).
Yes perfect!! Could you please explain this a bit further?
I see that rather than create a grid of construction lines you have created a grid of points but what have you done for each sketch '25mm holes', '38mm holes' & '75mm holes'? Have you projected geometry off the 'Grid Master' sketch?
TheCADWhisperer
@Anonymous wrote:
... Have you projected geometry off the 'Grid Master' sketch?
Yes.
