How to remove the shadow cast by a local light in rendering?
Message 1 of 12
Do you have any idea to remove the shadow cast by a local light in rendering?
Though I could remove the shadow cast by the environmental light using sub-options, I couldn't find any similar options for the local lights.
Anu helps will be welcomed.
Thank you in advance.
Replies (11)
Message 2 of 12
mdavis22569
For the local rendering ... are you using Inventor Studio?
if so you have to  turn them off here:
Mike Davis
Message 3 of 12
lena.talkhina
Welcome to the Autodesk Community @Anonymous !
Great to see you here on Inventor forum.
Hope you will find a solution soon.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 4 of 12
Thanks, Michael.
If you meant to use "View" -> "Shadows", it does not work.
Actually, it only works for the environmental lighting.
If you add any local lights, you may see that the options from "Shadows" tap won't work for the local lights....
Message 5 of 12
mdavis22569
Hi @Anonymous
Can you share a screenshots or screencast video showing what you're experiencing and what you'd like to remove ?
Mike Davis
Message 6 of 12
Thank you so much for your interest 😄
As you can see in the figure 1, I turned off the shadow options.
When I add a local light (figure 2), there happens a shadow (figure 3).
I'd like to remove the shadow cast by the local light.
I attached my inventor file.
Message 7 of 12
mdavis22569
Try adjusting these:
Mike Davis
Message 8 of 12
Catrik
Turning all those shadow settings to 0 doesnt fix the problem. In the CAD model there is no shadows at all, but no matter what settings I adjust, the rendered image always has shadows in it, making a picture like this look very messy and unclear.
I would just need the model to look exactly like in the 3D enviroment (including part being semi-transparent if it's set to "not enabled"), but with transparent background (looks like it's called Alpha channel).
Message 9 of 12
kacper.suchomski
Have you turned off ambient shadows?
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-3395B47F-7D8B-47B4-ACDD-0A9489948DB4
Kacper Suchomski
Message 10 of 12
Catrik
This topic is about rendering images with Inventor Studio. Model view settings do not apply to renderings.
Message 11 of 12
ldutkaTUZ58
Did you try "Visual Style", under "Appearance"?
Message 12 of 12
willie_roelofsNJHEF
When rendering, you're using a standard light source from the scene you're using, and I'm not sure how to disable it. However, to minimize shadows, you can set up a new light source aligned with the camera angle you're using to render the image, effectively nullifying the shadows. You can adjust the intensity until you've achieved the desired effect.
