How to remove a custom shape from a part
lloyd.infinger
Message 1 of 8
lloyd.infinger
I  am completely new to CAD software and I am in need of some help. I need to be able to remove a custom shape from a part. The shape that I need to remove material from is a cylinder. I need to cut some material away from the top of the cylinder. The material that needs to be removed is a five-sided shape. More or less triangle in the top.
I have been able to do this same task in tinkerCAD but I am now using Inventor Pro and would like to know how to make it work with this software. Any feedback would be greatly appreciated.
Replies (7)
Message 2 of 8
gcoombridge
Can you add a hand sketch or screen shot from tinker cad so we can see exactly what you mean?
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Message 3 of 8
lloyd.infinger
Here is the part I created in tinkerCAD. I need to be able to remove the red line from the cylinder.
Message 4 of 8
SharkDesign
You need to draw the shape once.
Cut it.
Use pattern to pattern it 3 times.
If you don't have a plane to sketch on you need to create a new one with the plane tool. Click on one of the origin planes and then on the cylinder to get it in a suitable place.
If all of this makes no sense to you, I can do a video in the morning step by step.
  Inventor Certified Professional
Message 5 of 8
gcoombridge
Part attached (Inventor 2021). I haven't followed your dimensions so it is a demonstration only. Not sure how much experience you have with inventor but when you get other peoples parts think of the browser on the left as a storyboard of actions. If you want to reverse engineer how it has been done roll up the end of part marker step by step.
Message 6 of 8
SharkDesign
Here's a video on how to do it.
https://knowledge.autodesk.com/community/screencast/083d7f98-9499-42e3-9139-23564cccd724
Message 7 of 8
lloyd.infinger
@SharkDesign @gcoombridge Thanks for the help. Yall made creating this simple part very simple. Just to let you guys know, I now know where my hang-up was. It was in the plane tool. I kept trying to do something very similar but by using the original three skitch planes. Thanks again for the help.
Message 8 of 8
JDMather
@lloyd.infinger wrote:
 I kept trying to do something very similar but by using the original three sketch planes.
That is the way I would do it - I very very rarely create any workplanes. Can you Attach your new file here?
