Dear,
I am a user of Autodesk inventor (2017) and am troubled with the yellow origin point of each seperate component displaying in all of my assemblies. How can I remove these dots (see screenshot below)?
This is important for me, so that I can show updates of my designs to my collegue's.
Thank you in advance!
Best,
Robin
Solved by cbenner. Go to Solution.
view>object visibility>uncheck 2D sketches
They'll be right back next time you open the assembly though.
I've been looking for a way to permanently hide workplanes and sketches myself. Haven't been successful unfortunately.
View>Object Visibility>Origin Points.
I have never experienced the behavior of setting, saving, closing and then on re-opening revert to visible.
I have the latest Update installed.
@TheCADWhisperer @Anonymous @Anonymous
I think (don't quote me) that if you do not create a View Rep for these changes to visibility to be saved to, they will return when the assembly is reopened. The default View Rep is locked, so changes made to that will not be saved. Create a new view rep and save it with a name you will recognize, then change the visibility settings and save the assembly.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
In an assembly file, I only see the Master View Rep. until one is created by the user. I've never seen a View Rep called default in a new assembly.
Chris Benner
@SBix26 wrote:
And here's what I see in Inventor 2019, using out-of-the-box Standard.iam template:
This has been my experience as far back as I can remember... Why do you suppose there's a difference?
Sam B
Inventor Pro 2019.0.0 | Windows 7 SP1
@SBix26 Best guess is either someone added that to your standard template file, or stripped it out of mine.... and on or both of us has been using the same template file for years, because (like you) I remember it being this way for a as far back as I can remember.
In either case, the original poster's concern is that he/she will have to use or create an unlocked View Rep in order to set this visibility and have it remain in place. (emphasis added for the sake of original question).
Chris Benner
None of these tips worked for me. I just want to get rid of the visibility of the yellow dot, however , unchecking "2D sketches" just hides the sketch without hiding the yellow dot. Unchecking "Origin Points" does nothing.
Post screenshot of what you see Shift Win S and Ctrl v into your next Reply
or
Attach your files here.
