How to "Insert Part" into another part and place around COG
I work in the precast industry and I am just starting to switch over to Inventor from SolidWorks.
I'm looking for the most efficient way to insert a lifter(s) into a concrete slab and automatically create the recess in the process.
In SolidWorks I could model a concrete product and then make it a multi-body part by using "Insert Part" to insert a lifter (which was another part file). I could then use the "combine" feature to create the recess while keeping the concrete slab and steel lifter intact.
Is there a similar way to do this in Inventor?
Keep in mind that my lifter part drawing in SWx had several configurations so if the design called for a heavier concrete slab, I could easily edit the lifter in the tree and switch it to another configuration with a higher lifting capacity and it would automatically update in the models, assemblies, and drawings.
I would prefer to keep this as a part instead of an assembly since we consider the concrete part with lifters as a single piece or section in my company but if an assembly or sub-assembly is a better option, I can work with that. Many of our products are meant to be assembled with each other to make a bigger structure (i.e. manholes, vaults, pipe layouts, etc.)
Another issue I have in relation to this is in Inventor, I have tried to "derive" the lifter into the concrete part model but I am not familiar with how to move/mate the lifters in relation to the center of gravity... Since these are large products, I need to accurately place the lifters evenly around the center of gravity to make it easier for cranes or forklifts to lift these without it tilting too much. I can't seem to do anything useful with the COG (can't project it, can't constrain anything to it, can't create a reference point with it, etc.)
Any tips for me? Thanks in advance!
