Inventor Forum
how to pattern around a square?
18 REPLIES 18
Message 1 of 19
CWC_Drawing_Office
1072 Views, 18 Replies
CWC_Drawing_Office
Hi all,
I would like to know how I can pattern a component around a square.
Thanks in advance.
Hi all,
Thanks in advance.
18 REPLIES 18
Message 2 of 19
admaiora
Hi Stacey,
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Hi Stacey,
Admaiora
Message 3 of 19
CWC_Drawing_Office
Thank you very much, could I apply this for a component in iam. environment? pattern a component around a square profile?
Message 4 of 19
JDMather
Yes.
Yes.
Message 5 of 19
CWC_Drawing_Office
Thanks JD.
Thanks JD.
Message 6 of 19
JDMather
You should probably hold your thanks until you figure out the tricks to do it.
Attach your assembly here if you can’t figure it out.
Message 7 of 19
CWC_Drawing_Office
Understood.
Attached is a pack n go of the assembly I am working on.
I wanted the connecting L-Bracket to be patterned around the square profile.
Understood.
Message 8 of 19
JDMather
I don't see a part named "L Bracket" and it is unclear to me which component you are referring to and where you want the Component Pattern?
10 minutes into this video...
Message 9 of 19
CWC_Drawing_Office
Apologies on that, I refer to it as an L-Bracket but it is a supplier part that has their unique name. The part I am referring to is the image below "Cartridge bracket".
Message 10 of 19
CWC_Drawing_Office
Thank you for the video JD, It was very comprehensive.
Message 11 of 19
CWC_Drawing_Office
I tried it JD, I patterned a point around my square profile at model level and then I tried to feature pattern the component at assembly level but I could not select the points for the feature pattern?
Message 12 of 19
JDMather
@CWC_Drawing_Office wrote:
.... but I could not select the points for the feature pattern?
@CWC_Drawing_Office
I just watched the video again and realized that I skipped over a step.
This is the most common stumbling block and I thought I had included the step in the video.
Because you did not Attach your new assembly here - I am going from memory and might have this slightly wrong.
To select the point pattern from the part click on Modeling at the top of the browser.
Then Expand the part history for the part with the point pattern.
You should now be able to select the point feature pattern from the browser history.
@CWC_Drawing_Office
Message 13 of 19
CWC_Drawing_Office
Hi JD,
Attached is an image of the feature pattern basing the 4 points at the centre of each line of the square.
 When I select okay, the point at the top disappears. Any idea as to why?
Hi JD,
Message 14 of 19
CWC_Drawing_Office
I tried navigating to the modeling tab by the browser to select the feature pattern, but said feature pattern does not appear in the part history.
Message 15 of 19
andrewiv
If you have an axis going through the center of that member you could just use a circular pattern to get the L bracket on all four sides.
Andrew In’t Veld
Designer
Andrew In’t Veld
Designer
Message 16 of 19
JDMather
Modeling Browser - not Model tab.
But I got lost in this hole Component Pattern driven by Feature Pattern technique.
As noted by @andrewiv - I think all you need is a Circular Component Pattern.
Message 17 of 19
CWC_Drawing_Office
Wow, super blind to that one! Thanks for the easy solution!
Message 18 of 19
CWC_Drawing_Office
Agreed, I myself got caught up in it. But nonetheless it is still a valuable lesson you've imparted that will definitely come in handy in different scenarios.
Message 19 of 19
WHolzwarth
If I'm understanding right, you could use a circular pattern for this task as well. It's more straightforward for me.
Walter Holzwarth
Walter Holzwarth
