How to open Autocad 3D in Inventor?
jesseHJ8N3
3.094 Vistas
13 Respuestas
Mensaje 1 de 14
jesseHJ8N3
Hi all,
I have an autocad 3D file from a supplier, which i want to look at using my spacemouse.
In Autocad LT, I can orbit the model by switching from Top to left etc. But i cannot look at it on custom angles.
How can I convert the autocad 3D file to a certain file output that lets me orbit freely in Inventor?
0 Me gusta
Soluciones aceptadas (1)
3.095 Vistas
13 Respuestas
Respuestas (13)
Mensaje 2 de 14
kacper.suchomski
Hi
Export to IGS
Kacper Suchomski
0 Me gusta
Mensaje 3 de 14
jesseHJ8N3
I can (within autocad LT) only export to:
.WMF
.BMP
.DWG
.DGN
.DWT
.DXF
0 Me gusta
Mensaje 4 de 14
Frederick_Law
AutoCAD 3D?
DWG file?
Just open it in Inventor.
0 Me gusta
Mensaje 5 de 14
LT.Rusty
Unfortunately, AutoCAD LT will show you the 3D, but will only give you the tools to work on the file (or export it) in 2D.
Have you tried opening the .DWG itself in Inventor? Sometimes you can get them to open, although I've only had spotty luck with that.
Failing that, you can download Navisworks Freedom and you should be able to open it in there to view in 3D.
Rusty
0 Me gusta
Mensaje 6 de 14
jtylerbc
@kacper.suchomski wrote:
Hi
Export to IGS
This would work, but is an unnecessary extra step.  Just use "Import DWG" in Inventor.  Inventor has been able to directly import 3D AutoCAD geometry for a long time, so there is no need to go through a neutral format.
0 Me gusta
Mensaje 7 de 14
johnsonshiue
Hi! Inventor can open or import AutoCAD dwg file (2D/3D). It should just work. Please share an example that is not working. I would like to understand the issue better.
Many thanks!
Software Test Engineer
Mensaje 8 de 14
jesseHJ8N3
When i do, it says "a valid inventor drawing template is required to open Autocad DWG files.
I have the autocad drawing template in my "default" folder.
I'm willing to send the drawing in DM, but i don't think it is an issue with the drawing as per.
0 Me gusta
Mensaje 9 de 14
jtylerbc
First, make sure you're clicking "Import DWG", not "Open DWG".  That's probably not the cause of your error, but will cause you to get different results than what you're looking for.  "Import DWG" converts the geometry to Inventor format, similar to importing a STEP or IGES file.  "Open DWG" would just use Inventor as a viewer for the AutoCAD file.
Are you able to start an Inventor drawing, or do you get a message about a missing template when you try to do so?
Mensaje 10 de 14
jesseHJ8N3
When I "import DWG" I get a warning saying: (...) Standard.iam was not found. I'm sure i have this one in my folder, as this is my "normal" assembly template.
When I "ok" that message, i see a plain 2D file with a lot of sketch symbols which are not visible.
0 Me gusta
Mensaje 11 de 14
CCarreiras
Can you share the file and we try to open it?
CCarreiras
0 Me gusta
Mensaje 12 de 14
jesseHJ8N3
Hereby in the attachments!
0 Me gusta
Mensaje 13 de 14
RajSchmidt
Solución aceptada
In Inventor 2023 I can open the file and view it, no problem. If I import it, I get an IPT with a bunch of faces. And during the import I can also choose the template.
Nonetheless, you should make sure your template is called “Standard.iam”. Autodesk changed the template names in localized versions a while ago. E.g. in the German version they were changed from “Norm.*” to “Standard.*”
0 Me gusta
Mensaje 14 de 14
jesseHJ8N3
Ah, The final part was the issue!
Bit surprised it doesn't just pick the one dwg template available.
Thankyou!
0 Me gusta
