I need to model a 1 inch round tube with a smashed end of about 2 inches. See attached photo.
How do I go at this?
Thanks for any help, Allen
Solved by JDMather. Go to Solution.
Hi
Use Loft tool.
Kacper Suchomski
There are several ways to do this and not too easy to explain. However I think sweep might be a good way.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-FCC0126F-50ED-449B-A0EF-1DED0287170B
What version of Inventor are you using?
Can you Attach the *.ipt file of your attempt here?
See Attached...
I didn't take the time to get it perfect.
This will do just fine. Thank you very much.
I was trying to use loft but with two hollow profiles and couldn't get it to work.
Thank you all for your input.
