How to mirror an STL file in inventor 2016 Pro
I did not create the file but I need to mirror the STL to 3D print a matching set.  Please help, I've tried using mesh enabler to covert it to a solid but it didn't work for me.
mcgyvr
Try this..attached
FYI... I just did it in my 3d printers software.. (CURA)
TheCADWhisperer
Will that give you a valid print envelope?
I was just experimenting in MeshMixer to try to improve the model.Discard Faces.pngDiscard Faces.png
TheCADWhisperer
johnsonshiue
Hi! Inventor generally lacks the ability to manipulate mesh objects. It can use it as a reference to create other geometry or drawing views but the ability to change mesh objects is limited to color or visibility. There is a free powerful mesh editing tool called Autodesk MeshMixer.
http://www.meshmixer.com/
It is free to use. Please try it out.
Many thanks!
Software Test Engineer
Thanks!!!
Thank You,
Cornelius Cooley, MBA
Engineering & Mathematics Teacher
Miller Career & Technology Center
PH: 281-237-7552
[email protected]
[Description: Description: Miller_Career_Tech_Center2]
This message and all attachments are confidential and intended only for use of the individual or entity to which it is addressed. Any review, use, dissemination, forwarding, printing, copying, disclosure, or distribution by persons other than the intended recipient(s) is prohibited and may be unlawful. If you have received this communication in error, please notify the sender immediately by replying to this message, delete this message and destroy any copy of it (in any form) without disclosing it.
