It seems I need the help of experts . I have 3 questions that I cannot find the answer to.
1) I have some old template files for part and weld-assy that when used will create a new file which starts in home view. I enclose them here.
As I remember, the only thing I had to do was to set the home view (iso with z = up) and save the file as template like that. I want to create new templates that works the same, but it seems I cannot do that anymore.
Did something change? If so - when and why? And how can I create such a template now?
2) When I create a new sketch in a newly created part file, the view flips around so that Y = upwards and not Z.
I hate that! Where can I turn it off? I do not want to turn on things or create things in the template, I just want the new file to open in ISO home view and not change when i click the sketch command. Current behaviour is unwanted, to put it mildly.
3) New assembly file from template: When created it opens in top view. That in turn makes it problematic to see how the first part is oriented when using "rotate x, y, or z" followed by "Place grounded at Origin", at which point the whole view flips around, causing confusion at least for me.
I would like the new assembly open in home view (I do not want to have to press F6) and stay there when i place the first component. How can I achieve that?
Please Look at enclosed files, and tell me how to create a new iam and ipn template that works alike!
