How to make part of alarm clock
Message 1 of 10
How are you able to make an .ipt of this part of a plastic part of an alarm clock?
Photos below.
Replies (9)
Message 2 of 10
Mark.Lancaster
@Anonymous
You would model it?  Or am I missing something..  Or are you asking us how to model it?
What Inventor version?
Are you looking to make the mold as well?
Do you know the dimensional values of this part?
Mark Lancaster
Message 3 of 10
TheCADWhisperer
Has your teacher taught you how to model Revolve features? Extrude features? Measure with calipers?
Message 4 of 10
mcgyvr
A quick attempt attached.. (modeled in 2017 version)
Message 5 of 10
Educational Version of 2016.
How do I make the part itself?
Which features/ribbons should I use to make this part? Extrusion? Revolve? There are a lot of things that he has not taught us yet.
The dimension values are 49.69 mm in diameter for the thick outer part of the ring. The inside circle is 42.64 mm in diameter for the inside, smaller part of the ring. The dimension of the little thickness is 1.59 mm and the height is 8.97 mm. 7.23 mm for squares. (Measured with Digital Calipers).
Message 6 of 10
Mark.Lancaster
@Anonymous
I'm adding my 2cents here...   Really, your instructor has not even taught you how to sketch and to create an extrusion yet?  That's basically like #1 in learning Inventor besides a few other stuff.  Even if that's the case..  This alarm clock would not be your first project.  Smiley Wink
If you did already learned how to sketch, and create an extrusion or even revolve.  Give a try yourself and then post what you have...
Mark Lancaster
Message 7 of 10
mcgyvr
@Anonymous Are you in class right now? If no when is your next Inventor class?
When that happens.. Get up and ask your teacher..
Let them know that you are having difficulty even getting started and let them actually "teach"...
Or just look at the part and use that brain... See what features you see..
Do you see circles.. IF so draw/extrude circles..
If you see squares.. draw/extrude squares..
Give it a try.. Model something.. Then post the ipt file (as far as you can get with it) and we can work with you (but your teacher should be a better source of instruction)
Message 8 of 10
Here's what I have so far
 Attachment.
Message 9 of 10
I have posted the ipt, I do not know how to add the extra little details. My teacher is skiing, he isn't here today.
Message 10 of 10
Rob67ert
Kick that teacher of the ski.
If he gets paid to teach you and you do this, I would like to have his job....I love skiing.
But forget that teacher and look in Inventor for the tutorials, there are some lessons on how to sketch and make features.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
