how to make iPart "SmartPart"
mitoborecek
Message 1 of 9
mitoborecek
Hi, is it possible to create a part such that when I insert it into an assembly, it will create a hole in the assembly at the location where I place the part? Like on the picture?
Replies (8)
Message 2 of 9
CCarreiras
Hi!
Not possible out of the box... but it's possible to enhance the process by pre preparing the hardware parts to help the process manually or even create an iLogic/VBa programing to do it automatically.
There are already lots of posts in this forum talking about similar processes.
CCarreiras
Message 3 of 9
mitoborecek
And how works this https://www.youtube.com/watch?v=7KjkCIIJmvA. If it works with inventor library, I thing could work with iPart with negative extrude feature or something
Message 4 of 9
CCarreiras
Bolted Connection is a specific function, iParts Doesn't work like it.
BTW, Bolted connection is a very faulty function, i prefer avoid it... but that's me...
Your thoughts about the negative extrude are somehow close... the difference is, instead of a negative extrusion (which you cannot have in a part, you will have to cut something) you can create a new volume solid representing the "hole" (turning the iPart in a multisold iPart).
When you place the iPart, you can copy that "hole" body to the part to drill and subtract using the tool COMBINE.
This process can be made manually, or automated with some programming.
CCarreiras
Message 5 of 9
mitoborecek
Thing like this in Solidworks. He makes inteligent object with features. He put handle with handle´s features  to assembly, and the handle makes automatically holes for screws in second part
Message 6 of 9
CCarreiras
Inventor doesn't have that specific tool, but this can be done with bolted connection.
Also, you can create a library for the most common cases to apply it quickly.
CCarreiras
Message 7 of 9
mitoborecek
is it only for circular holes or holes of any shape?
Message 8 of 9
CCarreiras
Only for holes.
For other shapes, you can pre set the parts similar to SW , but with a solid, and then you can do the rest manually, as i suggested before.
CCarreiras
Message 9 of 9
johnsonshiue
Hi! Aside from Bolted Connection, the closest workflow to SWX SmartPart in Inventor is Copy Object (Adaptive Bodies). Basically, when editing a part in an assembly, you can link to bolt geometry via Copy Object command. And you can use the linked geometry to create the hole.  The bolt will drive the hole location and size.
Many thanks!
Software Test Engineer
