in a drawing I made some lines invisible (right-click on the line, and uncheck visibility). how can I make these lines visible again? for obvious reasons I can not right-click on them (they are not visible), and I don't find them in the browser tree.
Daniel
Solved by SBix26. Go to Solution.
Right click on the view and Show Hidden Edges. All hidden edges will be shown in red, and selecting them changes them to green. Then right click > Done, and the green ones are now visible.
Is this function only available on windows? I don't seem to have this option on my Mac Ultimate version.
How do you get the original linework back after using the invisible linework tool? I made some halftone lines invisible using the linework tool. I now need them back. I used the linework tool to make thin lines but it won't let me select them to make them halftone. Is it possible to get the original linework back the way it was?
Are you sure you're in the right forum? I don't know anything about a "linework tool" in Inventor...
Sam B
Inventor Pro 2022.2.2 | Windows 10 Home 21H2
