I am building a revolution shell in solid parts design as a surface (shell). I draw the sketch, then revolve it 180º as a shell. Then I create another half by mirror. I need to assemble two different parts, the revolution shell (composed by the two halves, and for what I want, I must have these two separated) and another part. The problem is that when I create the assemble and I put the revolution shell, it appears as one single shell instead of two halves. I need the two halves for an analysis that I need to do later. How can I make inventor assume two halves instead of one single shell?
Thanks in advance,
Best regards,
Hugo Silva
Solved by salariua. Go to Solution.
Make the half shell and insert it twice in your assembly. Two parts. If you revolve it twice in one part, it's still just one part in your assembly.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Attach your files here if you can't figure it out.
hugolopessilva wrote:How can I make inventor assume two halves instead of one single shell?
The We would need pictures, and model to understand your problem but are you saying the model looks merged as a single entity rather than showing the split lines?
hugolopessilva wrote:The problem is that when I create the assemble and I put the revolution shell, it appears as one single shell instead of two halves.
The faces will be merged togheter so you would need to either splt the faces or create the mirror as separate body.But this is just an assumption without seeing the model.
