Inventor Forum
How to locate which part inside an assembly has had its weight manually ouverrid
2 REPLIES 2
281 Views, 2 Replies
I have an issue that occurs quite often. When reviewing assemblies, some are very large, I find that the assembly weight (in iProperties) has a hand indicating that either it's mass was overridden, or a part inside the assembly has had it's weight manually overridden. Is there a way to locate which part inside the assembly was overridden? I ask this after 1.5 hours of opening each part trying to locate which one was altered.
Has anyone else won this battle? I thought I have watched all the relevant tutorials pertaining to this subject, but I have been known to be wrong many times a day. Any help would be much appreciated.
2 REPLIES 2
Curtis_Waguespack
Curtis_Waguespack
Hi nostopin,
Here's a quick iLogic rule to look through the assembly and find the components with mass overrides. If found it asks you if you want to clear them.
Post back if you have issues with it.
I hope this helps.
Curtis
Edit: I left some remnants of my strip color overrides rule in the code the first time around, updated now.
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
oCounter = 0
For Each oOcc In oAsmCompDef.Occurrences
    oDef = oOcc.Definition.Document
	'Set a reference To the mass properties Object.
	Dim oMassProps As MassProperties
	oMassProps = oDef.ComponentDefinition.MassProperties
	If oMassProps.MassOverridden = True Then
		oQuestion = MessageBox.Show("Mass override in: " & _
		oOcc.Name & "Do you want to clear the override?","iLogic",MessageBoxButtons.YesNo)
		oCounter = oCounter +1
	If oQuestion = vbYes Then
		oMassProps.MassOverridden = False
Next
If oCounter = 0 Then
	MessageBox.Show("No mass overrides found.", "iLogic")
Hi nostopin,
I hope this helps.
Curtis
oCounter = 0
Next
in reply to: Curtis_Waguespack
Thank you Curtis, I will check this out Monday.
