How to link custom properties of the model to the part list of the 2d drawing
I am trying to link the custom property of the model "MATL REF SPEC" to the part list in the 2d drawing. I need another column in the name of custom property, in the part list of the 2d drawing along with the default columns. Please help me with solution. I have attached snapshots of application for your reference.
CCarreiras
Hi!
Double click your part list to edit.
Your User property must be listed among the standard iproperties.
You can use a filter to find it easily. Just double click the user propertie ar click "Add" and it will be in the part list.
CCarreiras
-niels-
Welcome to the forum!
You can add custom properties to your partslist with the column chooser:
Place your parts list.
Edit parts list.
Select "column chooser".
Click "New Property" at the bottom left.
Click "<<click here to add new property>>"
Enter the name of your custom property. (EXACTLY as you've defined it)
Hit Enter, then click on "OK".
The custom property should now be added to the right column listing all your default properties.
Hit "OK" again and see if it worked.
Hope this is what you need.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
