I'm adding a brace between to vertical members. I always want the offset from the top of the one member to be a certain number, in this case 1", and the offset from the bottom of the other member to be a certain number. Again, in this case 1" but this should be adjustable. I want to do the whole thing as a part not an assembly. I can handle the first offset but the way I did the second one involves computing the angle of the plane that the diagonal cross section is drawn on (or drawing it in 2d in Autocad to figure it out). The problem with this, of course, if I change the height of a column or the spacing or anything then I have to recompute the angle and edit it. Not what I would exactly call parametric.
Does anyone now how I could construct this so it would automatically keep the offset at a predefined number? If you look at the attached pdf, I'm talking about holding those two 1" dimensions constant.
已解决! 转到解答。
