Inventor Forum
How to insert own dimension in content centre
10 REPLIES 10
Message 1 of 11
rannia666Q6
420 Views, 10 Replies
rannia666Q6
I put someting in the content centre but i don't know how to make it so that i can change the length of the rail. it now looks like the file i included, but i need it to look like the other one
10 REPLIES 10
Message 2 of 11
CGBenner
in reply to: rannia666Q6
CGBenner
@rannia666Q6
Hello.  Was the part you published an iPart?  These table-driven parts in the Content Center usually start as an iPart with at least a couple of line items.  Once you have a table-driven part published, you can add as many rows to the table as you need.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
@rannia666Q6
Chris Benner
Message 3 of 11
rannia666Q6
in reply to: CGBenner
rannia666Q6
Yes it is a Ipart. but i dont need to add rows to the table. i just need to make sure i can adjust the length of the rail manually. because it is now static on 549mm. i understand if i expand the table i can insert more lenght options. but the length differentiates from 500 to 1000mm so i think its best people can adjust it manually.
Message 4 of 11
CGBenner
CGBenner
@rannia666Q6
Maybe it would help to understand more about how you are using this part.  Is this for building frames?  Or, do you place them one at a time into an assembly?
Chris Benner
@rannia666Q6
Chris Benner
Message 5 of 11
rannia666Q6
rannia666Q6
It is a rail used to mount electrical components. so there can be multipule rails in an assembly
Message 6 of 11
CGBenner
CGBenner
@rannia666Q6
Thank you, that helps. 🙂
You have a couple of options, I believe.
  • Place each piece "As Custom" from the Content Center.  This would create a new, unique part file each time and you could then change the length as needed.
  • Modify the Length column in your Content Center family and make it a Custom column with an expression similar to that in the images below.  Select the ellipsis (three dots) at the end of the expression window to enter your minimum, maximum and increment values for the length range you want.  This should gain you a prompt when you place the part, where you can enter the length as it is being placed.
Chris Benner
@rannia666Q6
Chris Benner
Message 7 of 11
rannia666Q6
rannia666Q6
I see that my data type is diffrent compared to yours. but i selected in the parameters Data: Real. i don't know what i did wrong.
Message 8 of 11
samanthalynnwatkins
I think the 0 needs to be larger such as 0.001. The 1 should be your max length.
Message 9 of 11
CGBenner
CGBenner
@rannia666Q6
In your image, you are trying to add the expression to the Filename column.  That won't work.  Could you possibly share your original (unpublished) ipart file here?  I can take a look at it and see what will work best for you.
Chris Benner
@rannia666Q6
Chris Benner
Message 10 of 11
rannia666Q6
rannia666Q6
Oh i see, i am sort of new to inventor so i'm still figuring stuff out. here is the file. thanks in advance!
Message 11 of 11
blandb
blandb
You are missing the 3rd value of the expression. Min/Default/max...looks like you may only have the min and default.
And @CGBenner  is correct, it looks like you are applying to filename. This will need to be on the vale that is controlling the length of the rail.
Autodesk Certified Professional
