I have a 2d geometry in a text file format. I would like to import this geometry and make 3d model in inventor.
Could anyone know how I can import a geometry text file in inventor?
Thank you,
Chinmai
Solved by chinmai-sai_jureddy. Go to Solution.
@chinmai-sai_jureddy Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Thank you for your reply.
I am sorry. I did not convey the question properly. I have a text file with points of the geometry. I found on the autodesk the following link on importing points in excel file. Which is also fine.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-D4A4288F-32F1-4E23-A382-930EBA152E87.
I used this and it worked. I can import points and inventor can connect the points with line/spline. I did this and modified the geometry further for 3D.
