How to hide assembly dimention?
safakgocmen
Observer Observer
Message 1 of 8
safakgocmen
Observer
Observer
Replies (7)
Message 2 of 8
EdvinTailwind
In the assembly tree there is a folder at the top called Annotations. There you can toogle the visibility.
Message 3 of 8
safakgocmen
Observer
Observer
Message 4 of 8
safakgocmen
Observer
Observer
Ekran Görüntüsü (1).png i found from there
Message 5 of 8
CCarreiras
HI!
These dimensions could be from a sketchs.
Hide the sketches 2D (and 3D if exists)
CCarreiras
Message 6 of 8
kacper.suchomski
Hi
Check which part files have visible sketches with dimensions, then turn off their visibility.
You'll probably have to open a few files to find the culprit, but if you've been doing this project, you shouldn't have any trouble finding it.
The option you used is also ok, but it's superficial.
Kacper Suchomski
Message 7 of 8
EdvinTailwind
@safakgocmen wrote:
thanks bu i dont have
I see that you found a solution, but the Annotations folder(s) could be in any of the sub-assemblies, not only in the top-assembly.
Message 8 of 8
johnsonshiue
Hi! The Component Annotation option in the Object Visibility should toggle the annotation visibility at all levels. If it does not work like that, it will be a bug.
Many thanks!
Software Test Engineer
