How to have new material appear in Materials Library
Vagulus
Vagulus
I have created a new specification for the 3D printing material acrylonitrile styrene acrylate (ASA) and have assigned it to a part using iProperties.  All okay so far.
I create a new part and want to assign ASA to it but ASA does not appear in the active Materials Library.
How do I migrate the material I have specified to the library?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
SBix26
No migration needed.  You simply need to save it to a material & appearance library.  Materials and appearances work very much like styles: you define them in a document, then save from the document to a library, where they are available to other documents.
Procedure: open the Materials Browser (where you created the material in the first place); right click on the new material and click Add to > followed by your chosen M&A library.
Don't forget-- Inventor has a lot of commands, procedures, and tools that are accessed by right clicking on something (context menus).  Don't be afraid to explore them!
Merry Christmas!
Sam B
Inventor Pro 2020.2 | Windows 7 SP1
LinkedIn
Vagulus
Merry Christmas Sam
ASA appears in the IPT iProperties
but it does not appear in the active Materials Library
My conundrum is how to have both 🤔
Albert Einstein
SBix26
Scroll the upper section of your material browser, which is the list of materials in your part file (LK-01-001.ipt).  When you find ASA in that list, right click on it and select Add to > PihanaDesignMaterials.
Sam B
LinkedIn
Vagulus
That's got it.
Thanks.
Albert Einstein
baliasM74U3
@SBix26  I follwed this same step. And defined 4 materials. What should I do to give different apperarences for each of these materials ?
