How to ground arbitrary geometry?
joh13399
joh13399
Hello, I have a sketch with 3 lines, 3 arbitrary, and one line connecting the midpoints of each. The midpoint connecting line has a dimension, like so: Screenshot_5.png
I want to edit this dimension, to make it 0.5 inches. However, when I edit this dimension, I do not want the line on the right to move at all. relative to the origin, all distances should be equal before and after the operation. This does not happen however, and the result is that both lines move.
Given that these 3 lines are completely arbitrary, how do I pin the line on the right such that its' position relative to the origin, and its size do not change? In assembly mode, I believe this is called grounding an entity.
jhackney1972
While in the sketch, select the line on the right and then select Fix, using your mouse, on the Constrain menu.
John Hackney, Retired
joh13399
This works well, it may be prudent to note that 'fix' only fixes the angle of the line, it seems that the length can still change if fixed.
SBix26
Then you will need to fix the end points as well.  Easiest is to window select all of it, then Fix will get all three entities.
But... Fix is almost never the best answer.  Best to connect the line to the origin with constraints and dimensions.  Is the origin center point projected into your sketches?  There is an Application Option to do that, and I strongly recommend it.
Sam B
Inventor Pro 2023 | Windows 10 Home 21H2
undefined
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
