Inventor Forum
How to give a name for subassemblies in iLogic?
9 REPLIES 9
Message 1 of 10
ikilic1461
543 Views, 9 Replies
In the example below , I want to give a name to a subassembly or subpart inside of the top assembly? Is anybody has any idea about it? Untitled.png
Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oDef As AssemblyComponentDefinition
    oDef = oDoc.ComponentDefinition
    ' Get the top level occurrence of an assembly
     Dim oOcc1 As ComponentOccurrence
    oOcc1 = oDef.Occurrences.Item(1)
    Dim oOccA As String
    oOccA = oOcc1.Name
    Dim oOcc2 As ComponentOccurrence
    oOcc2 = oDef.Occurrences.Item(7)
    Dim oOccF As String
    oOccF = oOcc2.Name
9 REPLIES 9
Message 2 of 10
Hi, try this line, change the names to your liking and with care
    Dim oOccA As String
    oOccA = oOcc1.Name
    Dim oOcc2_1 As ComponentOccurrence  'Set sheel course 1_4    Check item
    oOcc2_1 = oDef.Occurrences.Item(7)
    Dim oOccF_1 As String
    oOccF_1 = oOcc2_1.Name
    Dim oOcc2 As ComponentOccurrence    'Set sheel course 1_4_1       Check item
    oOcc2 = oOcc2_1.Definition.Document.ComponentDefinition.Occurrences.Item(1)
    Dim oOccF As String
    oOccF = oOcc2.Name
MessageBox.Show( oOccF_1 , "Title")   '  Check item
MessageBox.Show( oOccF , "Title")    '  Check item
 Regards!!!!
PD: You must keep in mind that with this method, you should not order the components because they will change places and the rule will give errors
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 10
Dear yuvilo_;
When I add that rules below, it gives error as photo below
    Dim oOccF As String
    oOccF = oOcc2.Name
Message 4 of 10
Try this rule only. Set if changing the element you can identify the piece or sub-assembly, then, if the dialog box is deleted, and then cut and paste them in your rule
On Error Resume Next
    Dim oOccA As String
    oOccA = oOcc1.Name
    oOcc2_1 = oDef.Occurrences.Item(6)
    Dim oOccF As String
    oOccF = oOcc2.Name
Mechanical Designer
Message 5 of 10
Dear yuvilo_ ;
I am grateful for your helps.
it is only  working ,  if  i add   "On Error Resume Next" .  But the error still exists.
Do I have any problem with that?
Why it gives that kind of error?
Message 6 of 10
the instruction on the error summarizes then continues the rule if an error is found, it does not stop at the error, place it so you can see the dialog box, and in that way the element is being modified until the piece is identified. if you still can not find shared files here to see them and accommodate them
Mechanical Designer
Message 7 of 10
Dear yuvilo_;
I attached it. you may see it. After delete "On Error Resume Next" in the rule , try to pass between 1 and 2 i described in the photo. Then it will give error. Vessel form.png
Message 8 of 10
Hi how are you, I have tried this code, I put the message boxes to help me find the error, then you remove them, there are recognized components that you initially needed
     Dim oOcc1 As ComponentOccurrence 'Left head name
    Dim oOccA As String
    oOccA = oOcc1.Name
	MessageBox.Show(oOccA, "Left head name")
	Dim oOcc3 As ComponentOccurrence 'Shell course_1_4 name
    oOcc3 = oDef.Occurrences.Item(6)
    Dim oOccC As String
    oOccC = oOcc3.Name
	MessageBox.Show(oOccC, "Shell course_1_4 name")
    Dim oOcc4 As ComponentOccurrence  'Shell course_2_4 name
    oOcc4 = oDef.Occurrences.Item(7)
    Dim oOccD As String
    oOccD = oOcc4.Name
	MessageBox.Show(oOccD, "Shell course_2_4 name")
    Dim oOcc4_1 As ComponentOccurrence    'Shell course_1_4_1 name
    oOcc4_1 = oOcc3.Definition.Document.ComponentDefinition.Occurrences.Item(1)
    Dim oOccD_1 As String
    oOccD_1 = oOcc4_1.Name
  	MessageBox.Show( oOccD_1,"Shell course_1_4_1 name")
On the other hand, it controls the instruction "if then else end if", it should be seen as a continuation
If Number_of_shell_course > 1 Then
Component.IsActive(oOccD) = False
Else
	Component.IsActive(oOccD) = True
End If
Component.IsActive(oOccD_1) = True
Else
	Component.IsActive(oOccD_1) = False
End If
Mechanical Designer
Message 9 of 10
Ok , thank you. It works well now. I may need for your further help ongoing times
Message 10 of 10
no problem, if I can help you with pleasure I will, remember that I have learned only and know basic things, I am not like many who are around here who are great teachers, if I can not solve something surely they can do it. If the comment served you mark it as a solution, we keep in touch. regards!! Man Happy
Mechanical Designer
