How to flange a circular face
Capture1.PNGHi,  I am trying to add a flange like the one show to outside curved edge of this sheet metal part. I have tried a contour role but it errors when I attempt to flatten it.  Any help would be greatly appreciated
Roelof.Feijen
1. Create a polygon.
2. Create a face.
3. Create your flanges.
See my screencast
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Curtis_Waguespack
Hi ken.perf,
How is this to be manufactured?
Often a round flange for a part as you show is a compound curve, in which case Inventor will not create that type of flat pattern.
Other times we'd create the curved flange as a 2nd part and weld it on the first.
The example Roelof.Feijen shows is a 3rd option I suppose, but I would suggest you run this by the folks in the shop before doing it in that manner.
I hope this helps.
Curtis
This flange will be put in with a seam machine. The curve is actually set up as a series of arcs to avoid using a 2d equation curve. I was afraid this would not be supported in Inventor 2013, does Inventor 2017 contain this functionality?
mcgyvr
@Anonymous wrote:
Does Inventor 2017 contain this functionality?
Nope..
IgorMir
Not very practical for a manufacturing... I would just weld a piece of flat strip to the edge of the main body.
Cheers,
Igor.
Web: www.meqc.com.au
johnsonshiue
Hi! Contour Flange was designed to tackle elbow joint design from a long piece. Your design requires so-called Sweep Flange, which is not unfoldable. You can create flange like profile at one end and simply sweep it along the circular edges. But, still the sheet metal part cannot be unfolded.
Thanks!
Software Test Engineer
