How to fix dimension lines?
Capture.PNG  In color red I marked the parts where dimension line doesn't quite touch the point it should. Is there a way to fix this, other than "cheating" and picking a different point that is a bit higher on the drawing?
Another thing I dislike are these extensions I marked in blue. Can I delete those?
Paul-Mason
How long have you ben doing engineering drawings and/or CAD? You SHOULD know that there IS NOTHING wrong with this dimensioning.
I would STRONGLY suggest that you lookup the relevant drawing standards for your country.
Inventor 2027 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
About the extension I do know they are fine but sometimes I would like to make them shorter. And about the problem I marked in red, I don't  know if it is allowed but I do know we never did that in college nor anyone mentioned it so I just assumed this is wrong.
MikeKovacik4928
Go to your manage tab, click on the styles editor, change your current dimension style or create a new one,
and change the settings A: extension to 0 and B: Origin offset to a value you want say 2
How to fix dimension line_001.jpgMichael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman/trainer
Inventor Pro 2018; Autocad 2018
Draughting/Designing (Manufacturing) (32 yrs)
-Drawing Board (3 yrs)
--Cad (29 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (5 yrs)
---Autocad and Inventor Simultaneously (5 years)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
JDMather
@Anonymous wrote:
...we never did that in college nor anyone mentioned it...
I recommend that you sue the college for malpractice.
What standard are you using?  ANSI/ASME? ISO?
What book did you use in college?
Did you keep your book for reference?
Do you own a Machinery's Handbook?
From Giesecke, et al Technical Drafting with Engineering Graphics
