Inventor 2020 and Vault Pro 2020
I'm using a 4k monitor on a laptop for the next 30 days of work-from-home.
I tried to save an ipt from Inventor with Vault's Automatic Numbering turned on. I can't get to the dropdowns to select the correct numbering scheme.
I have turned off automatic display scaling for Vault as discussed here: https://forums.autodesk.com/t5/vault-forum/changing-text-size/td-p/8851817
That helped make Vault usable, but did nothing for the Numbering dialog window.
Anybody have a solution?
Steve Walton
Solved by mdavis22569. Go to Solution.
Have you tried changing the HIGH DPI setting's
I had to select the "Change for All Users" button, then set the DPI setting to "System" not application.
Off to vote for more 4K support ideas...
Steve Walton
i'm working with 2022 profesional and i do not know how you got to this dialog box? it is not in the options settings that i can find.
Right click on the Inventor icon
