I have a derived mirrored part and I'm trying to fill in a hole so I can recreate it in a different position. This isn't as easy as it seems and it takes about 6 extrusion features to correct. Is there a simpler way to do it? i.e. filling the hole
I tried closing the hole up with boundary patches and then using sculpt but it doesn't follow the contours of the base part so you can see where the hole was.
I've attached the part which is J040817. The hole I'm trying to move is indicated on the attached image.
Solved by JDMather. Go to Solution.
Solved by mcgyvr. Go to Solution.
Delete face with heal option
Delete Face with Heal option.
Done!
