How to export STL file in an assembly
Message 1 of 8
Hi everyone!
Normally I use Autodesk Fusion 360. Now, for my new work, I have to use Autodesk Inventor. But I have some problem whit little easy problem!
I have an assembly whit 2 component. The first compenent whit one solid object, and the second one whit two solid object. How can I export in STL to have three differt STL file?
Thank you all for the help!
Matteo
Replies (7)
Message 2 of 8
mcgyvr
Simply open each part on its own and "save copy as" (or export.. cad format) to stl file.. remember to set the stl options before pressing the save button.
Message 3 of 8
Thank you for the reply.
If I do this, if I select the component, I save 1 file whit 2 solid in the same model. I don't want this. I want to save a single solid in STL.
Message 4 of 8
JDMather
Can you Attach your assembly here?
Someone will create a video for the process.
Message 5 of 8
I have this situation. I have to export in STL the three component. The files "Solido" and "Solido4_V2" have only one solid model. The file "Solido4_V2" has 2 solid: "Rotore" and "Rondella".
Message 6 of 8
mcgyvr
@Anonymous  Sorry.. I missed the part about the 2 solid bodies..
In that case you open each part then simply expand the solids folder in the model browser and right click on the solid and turn off visibility of that solid and save copy as.. Then turn it back on and turn visibility of the other solid off and save copy as..
Voila..
Message 7 of 8
johnsonshiue
Hi! Or, you can use Task Scheduler to export the folder or selected files to STL in a batch.
Many thanks!
Software Test Engineer
Message 8 of 8
Yes! Whit this method I did it!
Thank you all guys for the answers and have a nice day!
Matteo
