Is there a way to only show the factory files when searching for parts and assemblies in Vault? When searching in Vault, often hundreds of factory member files come up, so it becomes time-consuming to locate the main factory file. For example, I have a part file with an ipart table that has 100 members in the table. When I'm in an assembly, I select "place from Vault" and search for my main factory part file. Even when I type in the exact factory part file name, the search results show all 100 members as well as the factory part. I then have to scroll through all the members until I eventually find the factory part to place it in the assembly. So, is there a way to only search for the factory part and prevent the member files from showing up?
