Inventor Forum
How to engrave text and designs on a curved surface
14 REPLIES 14
Message 1 of 15
10432 Views, 14 Replies
I'm making s a (sort of) trumpet to be 3D printed, and as you may know, trumpets have a curved bell that tapers out. Many manufactures will engrave/ stamp their names and logos on their horns, and since I'm making mine to be used as fanfare during a FIRST robotics competition, I want to have the teams name and symbol (can I turn a Photoshop PDF into a sketch?) on the bell. I'm using Autodesk Inventor 2017, and I made the object by making a side profile and revolving it around a central axis. One thing important to note (he he, music pun) is that the engraving can not go all the way though, as that would ruin the instrument. Can this be done?
14 REPLIES 14
Message 2 of 15
mdavis22569
Hi ...and welcome to the forum
Yes you can put Text on a surface ...
here is an example
https://www.youtube.com/watch?v=K-XwGr_5j1A
List of videos on Google
https://www.google.com/search?q=embossing+on+a+curve+Inventor&source=lnms&tbm=vid&sa=X&ved=0ahUKEwj4...
I'm 3d printed text cut into and embossed out on a curve surface too.
Mike
Mike Davis
Message 3 of 15
in reply to: mdavis22569
The bell of a trumpet also flares out. Does this still apply? It's like a cylinder that tapers rapidly.
Message 4 of 15
mdavis22569
If you wrap it to face it should work ...
Can you attach the model ...
Try it first ...if you can't get it then attach a model and someone can make a screencast showing you how ....or do it for you
Mike Davis
Message 5 of 15
The part that flares out is like an inside out sphere, i made an arc flaring outwards and revolved that, there's no spot that's tangent to it all the way. I call it "not sure what to call it yet" because as you will see, its not really a trumpet.
Message 6 of 15
WHolzwarth
Here we go. Your first sketch was too complicated.
Engraving can be done, but is tricky. (2017 file)
Walter Holzwarth
Message 7 of 15
mdavis22569
Hi (Morning)
So you do it as you've shown, or the Flare as Walter (WH) has shown, but you cant do the shaft going up to the flare out ...
like I was trying to show here ...
this won't work
Did we answer your question
Mike
Mike Davis
Message 8 of 15
Yes, you answered it. Too bad it won't work, but thanks!
Message 9 of 15
mdavis22569
I should re-phrase it ..
It could be ..but it wouldn't be easy.. like the emboss tool.
It would have to be done how they would actually make it, in the flat, it would probably get distorted when they form it.
Another option I thought ( thought, not actually do) of was in Sheetmetal,   unfold the part and as it, but the curve would make it difficult
I was trying to run different scenario's of how it would be make over and over ..and then putting it into Inventor and nothing, the distorting kept coming into play.
If we did answer, can you pick one as a solution, so others know the outcome if they are looking for something similar
Mike
Mike Davis
Message 10 of 15
WHolzwarth
Well, not perfect is this one. But it seems good enough for 3D printing
Walter Holzwarth
Message 11 of 15
in reply to: WHolzwarth
Nice, Second robotics. So if I want it on the bell likee that, I'll have to do each letter separatly... ugh. I'ts actualy printing no, with the engraving on the easier part. I'll give it a go myself and print it where I orgignaly wanted it when I finsih troubleshooting with the original.
Message 12 of 15
WHolzwarth
WolfoftheMarrow schrieb:
... So if I want it on the bell like that, I'll have to do each letter separately... ugh.
There's no need for letters done separately. The whole text was made in a single step, but needs to be adapted to the shape of the trumpet.
Move EOP up and back down step by step, and you can see.
Walter Holzwarth
Message 13 of 15
I guess I'm still just getting my feet wet, I can hardly see how you did that. How did you make sketch 6? That seems to be the most important part that I don't get.
Message 14 of 15
WHolzwarth
Well, best plane for starting a sketch for the text is a tangent plane at the conical surface.
After that engraving the text to a separate body, 2 bends, another split body and rotate it, combine again, delete unnecessary faces, and a boolean cut at the end.
Walter Holzwarth
Message 15 of 15
TheCADWhisperer
@Anonymous
On another note - I made a few changes - see attached ipt file. (edit Sketch1)
