How to edit assembly fast
不适用
405 次查看
2 条回复
1 条消息(共 3 条)
不适用
could anyone advise me how to edit assembly fast? I have assembly which i want to divide and remove second part of assembly. Unfortunately, it is more than 700 Solids. I dont want to delete them one by one.
I wonder if it is possible to reduce hardware demands of this assembly.
Thanks for any advice.
Here is screenshot:
http://prntscr.com/9pjm8o
0 个赞
已接受的解答 (1)
406 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
SBix26
已接受的解答
What you're showing is not an assembly, it is a part file with multiple solids (695 of them, to be exact!).
There is no window select, unfortunately, but if your solid bodies are arranged in some logical order, you can multi-select in the browser, as you have shown in your screen shot (shift-click and ctrl-click).
I have done the same thing with imported files, and it can be quite tedious.
Sam B
Inventor Professional 2016 R3 SP1 Update 1
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
3 条消息(共 3 条)
mcgyvr
Sounds like something for the ideastation..
I HATE it when I find portions of Inventor where you can't window select... just silly..
applying constraints is another area where window select SHOULD be there..
