How to drive wheel - rotating automatic but not draging with mouse?
Could anyone from you tell me, how to run wheel with drive automatic. I have made a model, but only from dragging the mouse i can rotate the wheel.
Thank you in advance!
JDMather
There are three different techniques that you can use.
1. Drive Constraint
2. Animate Constraint (in Inventor Studio).
3. Input motion with Rolling Cylinder on Plane (in Dynamic Simulation).
Dynamic Simulation Rolling Cylinder on Plane Joint - YouTube
If you haven't figured it out by tomorrow - I will demo using your actual files.
(It might be a good idea to install the Updates for 2019 ).
To tell the truth I tried with drive constrain, but Inventor said: check adaptive settings.
At dynamic simulation at standard joints its created a planar but I cannot edit velocity and another options
JDMather
Extract and Open the Attached assembly.
Go to Environments>Dynamic Simulation.
Click Play...
What about driving with constrain. For example drive angle or drive flush? I tried but the wheel just rotated around its position
