How to drive gear to articulate mechanism
ScaleyZVFC5
ScaleyZVFC5
In the assembly (AS-01-test.zip) I attempt to Drive the angle of the 15 tooth spur gear from 0 - 45 deg. However I receive the error:
Cannot solve at (or near) this point. Check drive parameters and adaptivity settings.
My goal is:
  • Rotational motion of spur gear (Angle:4) and the pinion shaft to be driven from 0 - 45 degrees (for starters)
  • Spur gear to mesh with ring gear (Rotation constraint set to Ratio of 0.150). Ring gear is constrained in all DOF to grounded bearing block, so spur gear is expected to rotate and revolve within the ring gear
  • Lower arm to rotate about the bearing block's pivot point, being articulated by the orbital motion of the pinion shaft
The mechanism articulates as I expect if Angle:4 is suppressed and the 15 tooth spur gear is dragged live with the cursor. However the error occurs when I attempt to Drive Angle:4.
Thanks in advance!
Scott
Autodesk Inventor 2024.3
Windows 10 Enterprise ver. 22H2
Dell 12th Gen Intel Core i7-12800H 2.4 GHz
RAM: 32 GB
johnsonshiue
Hi! Suppress Angle:4. You need to add another Rotational constraint between the Lower Arm and the Spring Gear. Then drive Angle:3.
Many thanks!
Software Test Engineer
ScaleyZVFC5
Thank you @johnsonshiue for your reply.
However, the ring gear is fixed (fully constrained to bearing block). Only the 15 tooth spur gear can rotate and revolve. I can drag the spur gear live with the cursor as shown in the video below, but I need help to get the spur gear to be a driven motion (i.e. rotating 0-45 deg).
AS-01-test.mp4
Video Player is loading.
Current Time 0:00
Duration 0:11
Loaded: 85.47%
Stream Type LIVE
Remaining Time 0:11
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Do you have any thoughts to get around the error I listed in the original post?
    Many thanks for your reply!
    Scott
    johnsonshiue
    Hi! In that case, you need to ground the Ring gear and suppress Angle:3. Edit Rotation:1 change the Rotational constraint to be between the Lower arm and Spur gear.
    Many thanks!
    ScaleyZVFC5
    @johnsonshiue you solved it! Thank you very much.
    I learned from your solution that the Rotation constraint must be applied to two moveable components, with neither of them being grounded (or otherwise fully constrained to ground). Without your help I would not have thought to apply the Rotation constraint to anything but the two gears!
    The result is shown in the video below. Interestingly, there are two things to be aware of with this solution:
    1. The ring gear becomes nothing more than an ornament in this mechanism
    2. The expected ratio (22 teeth / 100 teeth = 0.22) results in an incorrect rotation. I had to change the ratio of the Rotation constraint to 0.2823 (28.3% higher) to achieve the intended rotation for this gear ratio
    AS-01-test2.mp4
    Current Time 0:00
    Duration 0:08
    Loaded: 100.00%
    Stream Type LIVE
    Remaining Time 0:08
    1x
      • Chapters
      (view in My Videos)
      Thanks again Johnson!!
      Scott
      Type a product name
      ______
      icon-svg-close-thick
      Cookie preferences
      THIRD PARTY SERVICES
      icon-svg-hide-thick
      icon-svg-show-thick
      Qualtrics
      Akamai mPulse
      Digital River
      Dynatrace
      Khoros
      Launch Darkly
      New Relic
      Salesforce Live Agent
      Wistia
      Tealium
      Upsellit
      CJ Affiliates
      Commission Factory
      Typepad Stats
      Geo Targetly
      SpeedCurve
      Qualified
      icon-svg-hide-thick
      icon-svg-show-thick
      Google Optimize
      ClickTale
      OneSignal
      Optimizely
      Amplitude
      Snowplow
      UserVoice
      Clearbit
      YouTube
      icon-svg-hide-thick
      icon-svg-show-thick
      Adobe Analytics
      AdWords
      Marketo
      Doubleclick
      HubSpot
      Twitter
      Facebook
      LinkedIn
      Yahoo! Japan
      Naver
      Quantcast
      Call Tracking
      Wunderkind
      ADC Media
      AgrantSEM
      Bidtellect
      Bing
      G2Crowd
      NMPI Display
      VK
      Adobe Target
      Trendkite
      Hotjar
      6 Sense
      Terminus
      StackAdapt
      The Trade Desk
      RollWorks
      Your experience. Your choice.
