How to draw something like this with Inventor Professional 2017?
My problem is that I dont' know how to draw this kind of pipeframed furnitures where the back rest is not in the same direction as YZ, XZ or XY planes. I'm also wondering how to create a sketch on the curved surface?
Replies (14)
mcgyvr
The frame to me looks like a fairly simple assembly of swept tube parts welded together..
Same for the cloth section..
I don't have 2017 so I can't share files with you but here is an image showing how to start one piece.. All the rest are very similar sweeps,etc..
Here is the first tutorial I found on creating sweeps..
https://www.youtube.com/watch?v=kjA7ASdaFTo
Cadmanto
@mcgyvr is correct on the sweeping a tube, but my thoughts are while that might work in some sections, you will need to create 3D sketches for other portions.  Here are a couple of videos explaining how to do this.
https://www.youtube.com/watch?v=w4J4SskvVu8
https://www.youtube.com/watch?v=toMgX6W3d4Q
As far as the cloth goes, I think applying some of the same techniques as shown creating the tube would work as well.  It would just have different profile shapes.  3D sketch would still be needed.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Yes sweep I can do, but hmm.. here is example. How to continue drawing to the same direction as arrow 1. at the spot where arrow 2. is, when that pipe 3. is like that?
mcgyvr
https://www.youtube.com/watch?v=LkxBLZ1VAlA
As stated by @Cadmanto you are going to need some practice in 3d sketches if you want this all as one continuous sweep..  Or a collection of multiple sketches to define the paths which may require creating workplanes,etc...
3d sketch could work, but what if I don't want to draw every lines in 90 degree angle? Here's a example of what I'm trying to say:esimerkki.jpg
Cadmanto
I suppose you don't have to use 3D sketch, but like @mcgyvr stated, you are going to need a whole lot of planes and possibly axis in obscure angles and positions to accomplish this.  We are just trying to suggest the easiest way to create the simplest model for what you are looking for.
Inventor Pro 2018
Best Regards,
Scott McFadden
So how can I create those planes and axis in obscure angle?
mcgyvr
Here is how to create workplanes..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Inventor/files/GUID-80FC6839-D432-4E7E-85C6-0F77E9AEDCC7-htm.html
Cadmanto
Here are a couple of tutorials on how to create angled work planes.
https://www.youtube.com/watch?v=8q6Z7QO9Llk
https://www.youtube.com/watch?v=9PezI2n963Q
Here is how to create axis.
https://www.youtube.com/watch?v=ZTmhVs1ZBz0
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
Inventor Pro 2018
Best Regards,
Scott McFadden
mcgyvr
Note you can use Ctrl+5 to turn off "ortho" mode while in a 3d sketch so its not always 90 degrees..
Thank's for your help!
Thank you for helping!
JDMather
Attach the *.ipt file here of your attempt and then I will show you the easy way to do it.
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Here is a quick screencast on how to draw the 3D Sketch for your chair as a quick attempt without any dimensional consideration, just to show you how it can be done.
Once you have the 3D Sketch created you can insert it into an assembly and use Frame Generator to create the tubing.
Attached are the 2017 parts, hope that helps!
Please select the Accept Solution button if a post solves your issue or answers your question.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
