How to draw rectangular/square helical curve in Inventor 2014
Dnyaneshwar_Maid
Dnyaneshwar_Maid
Hello all,
Can anybody show how we can draw rectangular/square helical curve in Inventor 2014
For referencing attaching one image
Thank you in advance
Best regards,
Dnyaneshwar Maid
Dnyaneshwar Maid
Design Engineer @MIBA,
Student Expert@Inventor
JDMather
Coil line.
Extrude rectangle as surface.
Fillet
3D Sketch intersection.
Sweep profile.
salariua
@Dnyaneshwar_Maid
I've done a similar thing but for Tube and Pipe. Instead of starting with a rectangle, add radius a to corners before doing second sketch.
check the video and post here.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
SBix26
Fillet.
2D Sketch inclined line at proper slope.
3D Sketch wrap 2D sketch line around surface, add extensions as needed.
Workplane normal to end of path, 2D sketch profile.
Sweep profile.
Edit: I still have 2014 installed; if you can't figure it out, I can produce a sample for you.
Sam B
Inventor Professional 2018.1.1
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
JDMather
A quick search turned up this thread.
https://forums.autodesk.com/t5/inventor-forum/making-a-rectangular-spring/m-p/3441447
Dnyaneshwar_Maid
Thanks a lot and its working for me.
Best regards,
Dnyaneshwar Maid
Dnyaneshwar Maid
