How to draw a logarithmic spiral
I'm trying to draw a logarithmic spiral using the equation curve button.
The equation of the curve i need to input is r(t): 2.718281828^(0.24*t)
Theta (t) can just be set to = t
I'm using Parametric and polar coordinates.
as soon as i do any function with ^t the text goes red. i think it's because it is getting unexpected units, but i dont know how to fix this...
I'm running 2015
swalton
Inventor is unit-aware.  You will need to make sure that your equation produces the units that the parameter is expecting.  Sometimes I will do an unit analysis of the equation before I input it into Inventor.
For example, say r(t) is in inches and "t" is in radians.  Use an equation something like this:
r(t): (2.718281828 in)^(0.24*t/(1 radian))
Steve Walton
Inventor 2025
Vault Professional 2025
yes, that's what i thought, but it still doesn't work.
Does it work on your machine?
johnsonshiue
Hi! Unfortunately, Inventor equation does not support logarithmic equations like this (variable in power).
Many thanks!
Software Test Engineer
