@Anonymous wrote:
How to divide a arc in 5 parts in sketch in Inventor as in AutoCAD?
Please help me.
Attach your file here.
Given that this is your first post here - I feel compelled to ask why you are sketching in a drawing?
Can you expand a bit on your problem statement and design intent?
I suspect there are better ways of doing whatever it is you are trying to do.
It doesn't matter where the drawings (Create New File -> Metric -> ISO.idw -> Sketch) or (Create New File -> Metric -> Standard.ipt -> Sketch) but how to divide arcs (no matter the number of arcs, as it should do as in AutoCAD option "Divide" and to be as polylines) into five equal parts?
I could show you how, but I don't understand why you would want to do this.
Can you supply more information on your design intent - ignoring AutoCAD techniques - I think there might be a better technique in Inventor.
Edit: And yes, it does matter where (drawing or part sketch).
I temporarily solved the problem with arc line between two point (arc length).
Whether there is a better solution?
I have no clue what your design intent is all about.
Provide more information and/or finish the design as best you can and then post that file(s) and I will show how I would have done the design.
I assume you mean something like attached file.
Here is your file with 5 equidistant divisions.
Here i have a sketch that contains of 50 dimensions. But now i want to split the sketch as sketch 1 & sketch 2 of each has 25 dimensions equal. Is it possible in auto desk inventor???????? Please help.
