Inventor Forum
How to dimension to a Insert Sketch Symbol?
4 REPLIES 4
650 Views, 4 Replies
How to dimension to a Insert Sketch Symbol?  I know it is very easy in AutoCAD, but inventor Dimension does not see my sketches. I am adding power and speaker locations to a room. I just need approximate locations.
It would be a hardship to have to model and insert speakers in the drawing.  I did that with track lighting bars.
I need to do the same with the Cat6, power, dimmers
4 REPLIES 4
mcgyvr
You can't..
You could place a work point at those locations though I believe..
another workaround here..
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
This is a duplicate, don't know how to delete duplicate.
mcgyvr
@Anonymous I notified the moderators to remove your other duplicate post..
This post should stay and be used for replies if needed..
Curtis_Waguespack
Hi ck1way-work,
I've had to do this in the past for some layout type work, and have done this:
  1. Select a View
  2. Create a sketch
  3. Project Geometry (you must select a view in step 1 to be able to project geometry)
  4. Create sketch lines
  5. Finish the sketch
  6. Place the symbols inserted on the sketch geometry
  7. Hide the sketch geometry
Note: In the video I used a layer to hide the geometry, but this might hide your sketch symbol geometry too, depending on your layer set up. So you might need to move the sketch geometry to a different layer and turn that layer off.  Or use the Sketch Only button when editing the sketch to make the lines only visible when editing the sketch (see image below).
I hope this helps.
Curtis
