How to dimension the apex of bend in drawing file
julietang
Message 1 of 30
julietang
hi all, i wanted to know if there was a proper way to dimension/annotate the apex of a bend on a drawing file. attached is a part i made and drawing file i placed it in. thank you.
Accepted solutions (4)
Replies (29)
Message 21 of 30
jyager
The lack of the willpower to not click every thread must be a horrific burden.
Jason Yager
Inventor Professional 2025.0.1
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
Message 22 of 30
Frederick_Law
OCD and or ADHD
I know I got OCD 🙊
Message 23 of 30
JDMather
@julietang
Step 1. Start a new sketch on the Right side (YZ Plane).
Sketch the three lines as shown with the Origin in upper right corner.
You can dimension the angle as 45° or as 135° as desired.
Add a sketch Point at the midpoint of the 3 inch line as shown below..
Edit your Sheet Metal Defaults...
Click on the pencil glyph
Set your Thickness parameter.
Select the Contoured Flange tool and set as shown...
Attach your progress here for next set of steps.
Message 24 of 30
julietang
Attached, Thank you. I do need to practice more using the contour roll feature. I usually start by adjusting sheet metal rule, start off drawing one face, then add flanges
Message 25 of 30
Frederick_Law
Setup Sheet Metal Styles for each thickness.
Message 26 of 30
SBix26
@julietang wrote:
... I do need to practice more using the contour roll feature.
Not the Contour Roll feature; the Contour Flange feature.  Contour Flange is very similar to Extrude, while Contour Roll is more like Revolve.
Sam B
Inventor Pro 2024.1.1 | Windows 10 Home 22H2
Message 27 of 30
JDMather
@julietang
Always use Symmetry when possible and practical.
This especially pays dividends when getting to Assembly.
I am going to demonstrate an alternate technique where symmetry is valuable.
Edit: There might be some cases where manufacturing doesn't want you to use symmetry as they don't know how to use their software and could benefit from training.
Message 28 of 30
JDMather
@julietang
Right click or Alt c and select Create Drawing View...
Select your drawing template or a blank template.
Select the right side of the View Cube...
Right click select OK.
Right click on the view in the browser and select Retrieve Model Annotations.
You can drag these to aesthetically pleasing positions and drag the connection points of extension lines to new locations if needed.
There is an Application Option to retrieve dimensions automatically, but unless all of your parts are relatively simple you probably do not want this active.
Right click on the 3 inch dimension and select Edit Model Dimension...
Change the 3 inch to 4 inch and click the green checkmark.
You just edited the part from the drawing.
I just wanted to demonstrate that you can edit these retrieved model dimensions.
Undo that edit to go back to the 3 inch dimension.
Edit: Double click on these images above to enlarge if they are too small to see on your screen.
Next we will experiment with different ways of placing the holes...
Message 29 of 30
julietang
Thank you!
Message 30 of 30
JDMather
@julietang
Right click on Sketch1 in the browser and turn on Visibility.
Start a New Sketch on the inclined face shown above.
Project Geometry the sketch point from Sketch1 into Sketch2.
Turn off the visibility of Sketch1.
Sketch the two circles as shown.
Sketch the vertical construction line as shown.
Add a sketch point where shown (not technically needed - but let's add it anyway).
