We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
How to Derive the hollow sections of a part into a solid? Please help.
Message 1 of 17
Hi there,
Need quick help on making the hollow section of my part a solid.  I assembled my part into a solid block that encompasses the part fully.  I then derived the part out of it which left me with the hollow part as a solid.  The problem is, is the block is still there and won't subtract out.  Is there another way of doing this?  Any help would be great.  Pic of part below, STEP file attached.  Thanks!
Thanks!
Accepted solutions (3)
Replies (16)
Message 2 of 17
TheCADWhisperer
Zip and Attach your Inventor files here.
Message 3 of 17
Here it is!
Message 4 of 17
johnsonshiue
Hi! I kind of understand what you are after and there are indeed better workflows to do what you want. To avoid any confusion, please attach the Inventor files here (zip them up before you attach).
Many thanks!
Software Test Engineer
Message 5 of 17
Hey John, It's attached right above your comment.  Thanks.
Message 6 of 17
johnsonshiue
Hi! It is fairly easy to do. In the imported part, turn on the visibility of XY plane. Create another workplane at the end of the barrel. Use Delete Face command -> pick a face so the solid becomes a surface. Use Sculpt command -> select XY plane, the new workplane and the surface body. You will get the solid of void. There are other ways to do that. This is just one of the ways.
Many thanks!
Message 7 of 17
Well... That didn't work for me.  Care to explain another way or maybe a bit more detail?  Really appreciate the help.
Message 8 of 17
TheCADWhisperer
The file that you attached here is a STEP file, not native Inventor files.
For the best advice - I recommend you attach native Inventor files (make up files if you design is proprietary).
There are multiple ways of doing this depending on your intended use/result.
Multi-body within a single part file (that can also be pushed out to individual parts/assembly).
or
Derive Component as surface body into a new part file and Sculpt or Stitch.
Message 9 of 17
johnsonshiue
Hi! Could you explain why it did not work for you? I would like to see your attempt and understand why the workflow I proposed did not work for you.
Many thanks!
Message 10 of 17
mcgyvr
Many thanks!
"pick a face so the solid becomes a surface"
What face? any face?
Different outcomes are possible depending on the users choice of "a face"...
Message 11 of 17
TheCADWhisperer
Something like this?
Message 12 of 17
Sorry, its habit to convert to STEP file.  Here is the .ipt.  I will try again.
Message 13 of 17
Well would you looky there!  Thanks!  You all are awesome.
Message 14 of 17
johnsonshiue
Hi! Here is another solution beside the one I mentioned earlier.
Many thanks!
Message 15 of 17
John,
Thats some next level stuff.  How'd you do the solid bodies function, surface bodies?  I see what you did. Looks handy.
Message 16 of 17
TheCADWhisperer
It would probably be a good idea to install the latest Update for 2017.
Message 17 of 17
Yeah i have the maintenance plan so I probably should!
