How to delete Electrical Properties?
Colbjørn
Colbjørn
Hi
How do you remove a componet from the Location View?
If you assign a componet electrical properties I'm not able to remove it again.
Jon.Dean
Hi Colbjorn,
If you created the link in AutoCAD Electrical then you may have to delete from there.
Did you try this?
Jon.
Jon Dean
Colbjørn
Hi.
The link is not created in AutoCAD Electrical.
You assign electrical properties to components in Inventor.
If you do so, it's not possible to delete the elctrical properties again so the component does not show up in the location view, as shown in the picture on top of the thread.
Colbjørn.
Jon.Dean
Hi Colbjorn,
Which version of Inventor are you using, I cannot tell from the screen-shot?
Would it be possible for you to create a screencast showing your workflow?
Jon.
Jon Dean
