How to define a sliding joint between linear carriage and a linear rail
manusha1980
manusha1980
I have STEP models of a HIWIN linear rail and a linear block. I would like to create a joint between these two so that the carriage can slide on the rail. Is this possible in an assembly?
WHolzwarth
No problem, if only carriage and rail are in the game.
If you're placing this combination in an upper-level assembly, it needs to be set as flexible. A single one will work.
If you're placing more than one set in an upper level assembly, sometimes you can run into problems.
Best way for further discussions is uploading your files.
Walter Holzwarth
