How to cut a frame member to a plane?
Hi again,
I've got a question about frame member cutting with a simple example posted below.
What I want to have is a frame member cut not to solid geometry but to a plane and for it to be robust - updating its length as it should when the skeleton line length changes. One would think - eaaaasy! But no...
I want the frame member to have the minimum length as specified in the skeleton and placed accordingly (along the sketch line and with the minimum length covering the line, not offset from it as it happens in the video*).
Things work great with the "start plane" side. But nothing seems to work for the "end plane" side of the member.
*In case someone was wondering why I ground the cut plane on "start side" - just so that Inventor doesn't throw an error/warning inside the frame member. Doesn't hurt, doesn't help much but it's clean and works.
As always - all sorts of help kindly appreciated!
