A loft that doesn't loft
tim.jager2001
Message 1 of 12
tim.jager2001
I have two sketches that I need to extrude between. Now the outlines and drill holes are identical, but the shaft in the middle shrinks by 1mm towards the bottom and if you look closely, you'll see that part of the bottom holes are also in the outline. In other words, I feel like this is what a loft should be for, connecting differently shaped surfaces, but I can't get it to work.
Any hints as to how I could do this?
Kind regards,
Tim
Replies (11)
Message 2 of 12
kacper.suchomski
Hi
The Loft command only supports one geometry in one operation. If there are multiple geometries, multiple Loft operations must be performed.
Since the outer contour is constant, Extrude will suffice. Then perform a Loft in cutout mode for the shaft geometry.
Kacper Suchomski
Message 3 of 12
tim.jager2001
Thank you for the suggestion.
It is something I thought about, but the thing is that the inner contour is quite complex and will in part be covered by the extrude, so I don't know how to solve that part efficiently. Like all the holes and such have to be identical as they now are. Am I missing something?
Message 4 of 12
YannickEnrico
The geometry exists in your sketches, doesn't it?
So if the geometry is covered by the first extrude, you can just share your existing sketches, and base a loft (cutout) on them
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Message 5 of 12
tim.jager2001
But how does that retain the inner geometry? Like, I have extrudes in multiple directions in there, so wouldn't they either get cut away, or filled in?
I also considered moving the extrude and cut into the past, but the plane to which it goes is based in a cut, so I can't really do the extrude before it.
Message 6 of 12
YannickEnrico
I think this is what you're hoping to achieve?
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 7 of 12
tim.jager2001
That is exactly it! Thank you!
Still having troubles working out how this mechanic works (and how to adjust it, because, as you probably guessed, I completely missed the way it should match on top side). But I think I can work from here.
Message 8 of 12
tim.jager2001
So I thought I got half of the process, so wanted to test if my thoughts were right, but got stuck way too soon. Any idea why Loft6 doesn't re-cut the hole?
Message 9 of 12
johnsonshiue
Hi! I am not sure why Loft has to be used here. You could use the profile in the middle to extrude as a solid body in one shot.
Many thanks!
Software Test Engineer
Message 10 of 12
YannickEnrico
It doesn't because I made a separate solid (so now there's two solids) to conserve any geometries while I was exploring what you tried to do.
Note how the bottom plate glows turquoise on your screenshot, while the other part glows purple on mine. (different colour scheme is tied to In-Canvas colour scheme in settings)
With multi-body solids you sometimes have to pinpoint what solid you're working on, because Inventor can only make its best guesses based on inputs.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 11 of 12
tim.jager2001
It is going from one shape to another, so I don't think that an extrusion is the ideal solution here. I also feel like it is a good learning opportunity.
Message 12 of 12
tim.jager2001
This just cleared all confusion I had. Thank you again!
